12-22-2008 04:28 AM - edited 03-15-2019 03:11 PM
Hi all, can any1 help
I am receiving below error in my application logs of Cisco Conference Connection
Version - 1.2(2), 1.2(2) SR1, 1.2(2) SR2
Log
Event Type: Error
Event Source: DCMS
Event Category: None
Event ID: 1
Date: 12/22/2008
Time: 3:54:51 PM
User: N/A
Computer: CCC
Description:
No channel entry includes 'g711Alaw64k'.
Event Code:0
Module: Gateway
Administration Conference
File: ahccodec, line 453
Moreover in ccm 413(sr5b) i have PCM type g711alaw, while when i chcked 2800/2651 voice gteways the calls show g711ulaw as codec.
help is gr8ly appreciated!!!
12-22-2008 11:44 PM
Hi all,
ny bdy wanna help???????
12-23-2008 01:46 AM
what are the symptoms?
If you use only G711ulaw same issue?
For internal conferences same issue?
when u noticed this behaviour?
CCC is EoS almost end of support we are encouraging our customers to go to MPE
You can check: CSCee92393
Audio quality issues when using multiple RTP packet sizes
Configure all devices to use the same packet size, such as G.711ulaw 20ms.
This is not possible in all cases
12-30-2008 12:25 AM
Hi there,
I have posted the detail,, any help, i know its EOS, but if client still needs somthing from forums, i think it may be fulfilled.
12-23-2008 01:17 PM
As long as i do conferencing within uae, no audio degrade happen. when users from other pstn or celllular networks connects lets say 4rom germany, turkey. the audio quality degrades,, i.e. scattered audio, echo, delay.
we have e1/pri. also in cucm 413 we have settings on gateway(mgcp) PCM type:alaw while on gateway : it is ulaw under dial-peer
when any call connects its shows in show voice call summ "g711ulaw" as codec..
Is it happening coz of mismatch on cucm & gw the pcm type
12-28-2008 08:58 PM
Hi all,
Any clues??????????????
