ut cli reports empty
Dec 22nd, 2008
When running all reports from GUI, all is fine, when running the reports from UT -cli, for example a switchportreclaimreport, the result is empty, no error messages displayed
Joe Clarke Mon, 12/22/2008 - 06:47
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of Campus Manager are you running? How are you running ut -cli? What output do you get on the command line?
lni1 Mon, 12/22/2008 - 23:55
We are running LMS 3.1 eval version (LMS 2.6 in production but without Campus manager).
When I run the "reclaim unused up", unused for 2 days in the GUI, everything works fine,see attach. When I run the same command from ut -cli : ut -cli -switchPortReclaimReport type down days 2 -devices all -u admin -p admin the result is the following :
C:\Documents and Settings\adm_lni>ut -cli -switchPortReclaimReport type down day
orbProperties={org.omg.CORBA.ORBInitialPort=42342, org.omg.CORBA.ORBClass=org.ja
corb.orb.ORB, org.omg.CORBA.ORBInitialHost=HICTATRIUSE001, org.omg.CORBA.ORBSing
letonClass=org.jacorb.orb.ORBSingleton, jacorb.implname=CSEDSPersistentIOR, org.
omg.PortableInterceptor.ORBInitializerClass.bidir_init=org.jacorb.orb.giop.BiDir
ConnectionInitializer}
[email protected]
License warning message: This software is provided for evaluation purposes only
and will be operational for 90 days. This software can manage only 100 devices.
If this is not an evaluation copy, Please click the pop-up message in the user i
nterface for more information. Otherwise, please contact your Cisco representat
ive for purchasing information.
log4j:ERROR No appenders could be found for category (com.cisco.nm.ani.clients.u
tng.application.UTDataManager).
log4j:ERROR Please initialize the log4j system properly.
Device,Port,Port Name,Operating Status,Admin Status,Last Used
Joe Clarke Thu, 12/25/2008 - 11:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is a bug. If you open a service request with TAC, and have your engineer contact me directly, I can provide an experimental patch.
