CUCM 6 Hardware Compatibility
Answered Question
Dec 22nd, 2008
Guys,
I am having problems installing CUCM6 on a HP DL380(G5) with below spec.
HP DL380(G5) 3.3GHz/1333MHz 6MB L2
2GB RAM
300GB HDD Space on Raid 5
The install fails with the below message:
Critical Error:
The Hardware you are using is not supported for this product. Installation will now halt.
I have checked the hardware compatibility matrix on Cisco.com website and I am not entirely sure how up-to-date the information on the site is. It says HP DL380-G5 (2 CPUs) with 2.33GHz is a supported platform for Cisco Unified Communications Manager 6.1.x. So if 2.33GHz is supported then 3.3GHz should also work in theory? Is there any patch or something I need to run before I run the install? Please help.
Appreciate your help, many thanks.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Correct Answer by Jaime Valencia about 8 years 6 months ago
the specs from www.cisco.com/go/swonly need to be a PERFECT MATCH. not similar. exact part numbers outlined there are what the install disk will look for, if they are not found you'll get that error
java
if this helps, please rate
Overall Rating: 3 (1 ratings)
Correct Answer
Jaime Valencia Mon, 12/22/2008 - 08:38
  • Cisco Employee,
  • Hall of Fame,
    2011
java
