Configuring FAX numbers
Dec 22nd, 2008
I wants to configure the Fax numbers, for that
My IPCC set up is:
ICM - 7.2
CVP - 4.0
Gateway - VG3845
How to configure the FAX Numbers?
What are the steps I need to do it?
Nicholas Matthews Tue, 12/23/2008 - 07:06
If you have a fax machine, you have to hook it into your network somehow. Unless this fax machine has an ethernet port, you won't have anywhere to connect it without an FXS port.
