Unity Server Hardware Upgrade
Dec 22nd, 2008
I have currently Unity UM version 4.05 and want to upgrade server and upgrade Unity to version 5. My plan is to extend schema (Unity version 5),upgrade current production version to 5, install latest DiRT, and run a backup. Next, install new server into domain using a new server name, install Unity version 5, integrate with Exchange (2003), take production box off network, and then do a DiRT restore on new server.
Does anyone see a flaw in this process? Thanks!
Tommer Catlin Mon, 12/22/2008 - 10:48
Looks good! I would maybe test the Unity 5.x server after its built. Create a new Subscriber, new integration to CUCM and see how it works. (MWI, TUI, etc)
mwheinz Fri, 01/02/2009 - 09:14
Thanks! I'll do that first thing, before i start on the rest.
Thanks again for your response!
mwheinz Fri, 01/02/2009 - 09:15
Thanks for taking the time to respond, your input is valued.
