7925 Wireless Phone and CCM 6.0
Dec 22nd, 2008
Looking at the datasheet for the 7925 it seems that the phone is widely supported across many CCM versions.
Does anyone know what version of 6.0 needs to be installed to add a phone in CCMAdmin?
The menu goes from 7921 --> 7931.
Aaron
Overall Rating: 5 (2 ratings)
Chris Deren Mon, 12/22/2008 - 08:18
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
You should be able to get it to work with the latest device pack.
HTH,
Chris
Rob Huffman Mon, 12/22/2008 - 08:43
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi Aaron,
Here is a little additional info to the good tips from Chris (+5 points Chris - Happy Holidays)
Before installing the firmware, use Table 1 below to verify that your Cisco Unified Communications Manager supports the Cisco Unified Wireless IP Phone 7925G. If your Cisco Unified Communications Manager does not support the Cisco Unified Wireless IP Phone 7925G, you will need to upgrade to a Cisco Unified Communications Manager release that supports the phone and/or install a device pack that will add the support for the phone.
Table 1: Cisco Unified Communications Manager Release Requirements for Cisco Unified Wireless IP Phone 7925G Support
CUCM Release
Minimum Service Release (SR) Required
DevicePack Required?
DevicePack Minimum Release
Notes
4.1(1) - 4.1(3)
Yes
4.1(82)
Install device pack
4.2(1) - 4.2(3)
Yes
4.2(3.55)
Install device pack
4.3(2)
Yes
4.3(2.08)
Install device pack
5.1(1) - 5.1(2)
5.1(3)
Yes
5.1.3.4114-2
Upgrade to 5.1(3) and install device pack
5.1(3)
Yes
5.1.3.4114-2
Install device pack
6.0(1)
Yes
***DevicePack Minimum Release 6.0.1.3112-1
Install device pack
6.1(1)
6.1(2)
Yes
6.1.2.1120-1
Upgrade to 6.1(2) and install device pack
6.1(2)
Yes
6.1.2.1120-1
Install device pack
7.0(1)
Yes
7.0.1.12004-1
Install device pack
http://www.cisco.com/web/software/282074289/23369/cmterm-7925-sccp.1-3-1-Readme.html
Hope this helps!
Rob
Chris Deren Mon, 12/22/2008 - 08:50
  • Hall of Fame,
Happy holidays Rob,
You continue to amaze me with your patience and detailed responses. As always well deserved 5 points for you.
Chris
Rob Huffman Mon, 12/22/2008 - 09:45
  • Hall of Fame,
    Founding Member
Hey Chris,
Thanks so much for your kind words my friend! They mean alot coming from a fellow NetPro whom I really admire.
Have a Rockin Festive Season.
Cheers!
Rob
acjarvis Mon, 12/22/2008 - 10:04
Rob-
Thanks for your reply. When checking the software download site the latest version I see under
CUCM V 6 --> Device Packages is
6.0(1.3109)
Maybe its not released yet?
Aaron
acjarvis Mon, 12/22/2008 - 10:50
The same thing applies to 6.1.2
Latest device pack for 6.1.2 is
6.1(2.1113)
7.0 doesn't have the listing for device packs as of yet.
Perhaps they will be released soon....considering the phones are shipping??
Rob Huffman Mon, 12/22/2008 - 11:20
  • Hall of Fame,
    Founding Member
Hi Aaron,
Good call! I'm sure these Devpaks are right around the corner.
I would open a TAC Case and see if they can't setup a special file access for you if you need it ahead of time.
Hope this helps!
Rob
