Syslog 11 giga !!!
Dec 22nd, 2008
I have installed an lms 3.1 one week ago with 200 devices (only) and the file
d:\CSCOpx\log\syslog.log is allreaddy 11 giga.
Also the file :CSCOpx\database\rmeng\syslogsecond.db is 6 giga.
Is there a setting that I misconfigured ?
Or is it possible to change the folder of these log ?
Thanks in advance.
Michel misonne
Joe Clarke Mon, 12/22/2008 - 08:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You need to configure log file rotation under Common Services > Server > Admin > Log Rotation. This will alleviate your syslog.log issue.
As for keeping the syslog dataspaces small, you will need to tweak your syslog purge policy under RME > Admin > Syslog > Set Purge Policy. This won't help your current problem, as the dataspaces will not shrink. However, you can contact TAC, and get the DBSpaceReclaim.class file which can free up the space.
mmisonne Mon, 12/22/2008 - 09:03
Hi Jclarke
What do I need to configure in log rotation
By default :
- backup dir : CSCOpx\log\
- config log file : nothing
Do I need to configure a log file. Wich log file : the syslog.log ?
Also, can I errase this log to get space ?
Michel.
Joe Clarke Mon, 12/22/2008 - 09:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You need to specify the path to syslog.log as your log file. Configure the desired max size, and whether or not you want to use compression. If you want to keep backups of this file, specify how many backups to keep. If you specify 0, then no archives will be kept.
You cannot simply delete this file.
Jason Fraioli Mon, 12/22/2008 - 11:26
Jclarke,
In LMS 3.1 I do not have the path to the log rotation mentioned in your previous post. Where might I find the log rotation configuration for LMS 3.1 with RME 4.1
Joe Clarke Mon, 12/22/2008 - 11:30
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You have LMS 3.0 or 3.0.1, then. LMS 3.1 comes with RME 4.2. To configure logrot in LMS 3.0, you need to run NMSROOT\bin\perl NMSROOT\bin\logrot.pl -c . You should also consult the online help for more details. Search the help for logrot.
richard.tetu Thu, 01/08/2009 - 06:11
Hello, jclarke does the tool DBSpaceReclaim.class could be used in LMS 2.6 and RME 4.0.5 ?
The fact is that my customer has launched the
logrot tool but, the syslog is so big that it can't be opened .
Richard
Joe Clarke Thu, 01/08/2009 - 07:23
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
DBSpaceReclaimer has no impact on log file size. Logrot has been specially written to handle log files over 2 GB. If you're seeing a problem rotating such logs, start a new thread.
richard.tetu Fri, 01/09/2009 - 02:04
Thanks JClarke and sorry , i will opened a new thread.
Richard
