Facing problem while Configuring SNMP in LMS 3.0
Dec 22nd, 2008
I have installed LMS 3.0 in a Dell Machine with Win 2k3 R2 successfully.
But when I tried to configure snmp it is giving many errors.
when I am clicking on snmp settings it is poping up SNMP Exception Massage:Excepton in connectToCampusServer()
And if I still configured snmp parameters & click OK it is giving page of errors saying "The server encountered an internal error"
I am attaching the errors pls have a look on it & pls advise.
Thanks in advance
Joe Clarke Mon, 12/22/2008 - 09:46
Please post the output of the pdshow command as well as the NMSROOT\MDC\tomcat\logs\stdout.log.
sachidananda panda Mon, 12/22/2008 - 09:49
Hi JC,
Thanks for ur quick response. I have already left the site shall post the same tomorrow same time.
sachidananda panda Tue, 12/23/2008 - 06:40
Hi JC,
Pls find the stdout.log & pdshow output as requested by you.
I tried by deleting the divicediscover.properties & putting back the .orig by renaming again to divicediscover.properties. but that also didnt work.
Joe Clarke Tue, 12/23/2008 - 09:58
Doing that will only breaks DeviceDiscovery if you are running Campus Manager 5.0 or 5.0.1. What version of Campus Manager is this?
Joe Clarke Tue, 12/23/2008 - 10:29
The pdshow output was truncated, but what it did show was that the system is severely damaged. I'll need to see the entire output before I can identify any root causes.
sachidananda panda Tue, 12/23/2008 - 13:10
Actualy I was supposed to send the entire pdshow output but I couldn't capture them.
Is it ok to re-install everything (OS as well as LMS) as its a ne installation there is nothig to lost.
Joe Clarke Tue, 12/23/2008 - 13:11
You can reinstall, but without identifying an underlying cause, the problem may return.
If you do reinstall, the best practices are to do the installation as a local Administrator on the server's console. Disable anti-virus software, and set the TEMP and TMP environment variables to short values (e.g. C:\WINDOWS\TEMP).
