remote sip phones fail to register on ccme
Dec 22nd, 2008
I'm trying to get 2 phones (analog phones connected to a Linksys PAP2-NA) to register on CCME. These phones are located in a remote network and they are able to reach our CCME over a L2L IPsec VPN. Site-to-site connectivity is fine, router configs are working as well since I can get the PAP to register on CCME if I put it on my local network, the problem is happening now that I placed the PAP in the remote lan, it just can't register with CCME. I'm also sure that user id and passwords are configured correctly on both sides...
Any ideas?
I believe it's IP related but can't find out exactly what I'm missing...
Thanks in advice.
Guilherme
Nicholas Matthews Mon, 12/22/2008 - 09:51
Hi Guilherme,
This is an intricacy with SIP CME. If phones register over the directly connected subnet they do not require a username and password configuration. If they register on a different subnet, it is required.
In the SIP messaging we're sending 401 unauthorized, which after the phone receives it, it should be sending another register with authentication, but it's not.
Make sure that under each of the ephones you have the username and password defined, and I'm not sure exactly how you're supposed to put this into the Linksys phones but they should have a format for inputting this information.
hth,
nick
guilherme@multi... Mon, 12/22/2008 - 10:02
Hi Nick,
Actually the phone does send another register request after the ccme sends that 401 unauthorized, I just didn't copy it to notepad, sorry.
Edit: I forgot to say it's a Linksys PAP2 (ATA) with 2 FXS, so I have 2 analog phones attached to it. I know where to put the username and password information into the Linksys and I'm sure it's correct (because it authenticates normally if connected to same lan as the cme).
Initially I thought it was related to mac id authentication but even setting the mac auth to zeros it still doesn't work.
Best regards,
Guilherme
Nicholas Matthews Mon, 12/22/2008 - 11:29
I would change the MAC address to the correct MAC address, see if that helps. You can also try a different form of ID in that command.
We should be sending a 200 OK to the register, do you see that in the logs?
3rd party phones aren't officially supported for CME, so it's hard to say if they'll register remotely correctly.
guilherme@multi... Mon, 12/22/2008 - 11:39
Changing to the correct mac address doesn't works either. I tried changing the ID to network and IP address but the router says only mac address ID is supported in CME mode...
No, no "200 OK" at all. All I got in the logs are those messages I attached to my first post.
I'm stuck at this point right now, don't know what else I can try but it's really weird, the ATA can register normally when connected to CME's lan (even if it's not in the same VLAN).
Nicholas Matthews Mon, 12/22/2008 - 12:21
If you post the full ccsip message debugs when the phone tries to register with the password I'll take a look.
my best guess is that the phone isn't doing something correctly in the re-register to the 401
hth,
nick
guilherme@multi... Tue, 12/23/2008 - 03:00
There's the full ccsip debug. Let me know if you need some other debugs/confs.
Thanks!
P.S.: I disabled the second phone to make the debug easier to analyze.
Best regards,
Guilherme
Nicholas Matthews Tue, 12/23/2008 - 07:03
Hi Guilherme,
This is as I said earlier - the phone never sends a re-register with authentication information. This is a phone configuration / interop issue.
CME doesn't officially support third party phones, so you would want to look at this from the Linksys phone.
It should be sending an authentication header in the register and it never does.
hth,
nick
ccievoice007 Thu, 01/22/2009 - 15:29
Nick,
Have you got Cisco phones registered to CME on a different subnet?
I'm trying with 7960/7962 and having no luck. I'm getting the same as Guilherme in that a 401 Unauth message is being returned to the SIP phone. I am using IOS 12.22T and P0S-08-6-00 on the 7960.
Locally attached phones register fine.
I have username for authentication set to Extn number defined in Voice register pool. Password defined in the pool matches that defined on the phone. The realm is something that I cannot change on the actual phone so it is set to an arbitary value (cisco).
Nicholas Matthews Thu, 01/22/2009 - 15:32
Yes, I do.
I don't have any 7960's currently, but I have before.
The phone will download the authentication data in the .cnf.xml file it downloads via TFTP. I have found that the CNF auto-update doesn't work as well for SIP CME as it does for SCCP. If you have configured your phone, tried to register, and added the authentication without manually doing a 'create profile' in voice register global, I would start there.
I would then check 'debug tftp events' to make sure you're downloading the file.
hth,
nick
ccievoice007 Thu, 01/22/2009 - 17:22
Thanks for your response.
I'm 100% sure the 7960 phone is receiving the cnf file via TFTP- I even deleted the cnf file of the phone. I can see it downloaded using deb tftp ev. It shows the correct DN on the Line1 setting.
The problem is as follows.
debug ccsip message is showing the router sending back a 401 Unauthorized. In the second REGISTER coming in from the 7960 phone there is no username being returned. In fact there is no authorization header in the REGISTER message.
So this goes into an endless loop- 401 Unauth is return and the phone returns a REGISTER with no authorization details.
Seems to be a firmware issue on the 7960- can you tell me which firmware you have used?
Nicholas Matthews Thu, 01/22/2009 - 17:35
Well, the next step then would be to make sure that the configuration file has the authorization information.
I believe you'll be doing something like this:
more system:/cme/sipphone/SEP.cnf.xml
debug tftp events will have the full name. Don't let the DN trick you - SIP phones are much different from SCCP. They will show the last DN they registered with, even if they aren't registered. They have more of a memory than SCCP phones do.
You should see something similar to this:
a
a
If you can confirm the .cnf.xml file has that in there, and the phone downloads it, then it's a phone firmware issue. 8.6.0 is pretty recent, and I don't think this is the case.
hth,
nick
ccievoice007 Thu, 01/22/2009 - 19:12
Nick,
The phone downloads a SIP.cnf file and not the SEP.cnf.xml which is used for SCCP registration to telephony-service. The create profile cmd under voice register global creates this file.
Take a look below and it has the necessary authorization information:
BR2-RTR#more SIP000D299D348C.cnf
image_version: "P003-08-6-00";
version_stamp: "0003002554414042";
user_info: "phone";
line1_name: "3006";
line1_displayname: "";
line1_shortname: "";
line1_authname: "3006";
line1_password: "cisco";
Thanks for your any light you may be able to shed.
Nicholas Matthews Thu, 01/22/2009 - 19:26
What IOS version are you on?
My 22T router shows this:
nicmatth-sip#dir system:/cme/sipphone/
Directory of system:/cme/sipphone/
249 -rw- 175 cme_dialplan_1.xml
237 -rw- 0 OS79XX.TXT
250 -rw- 2809 SEP001794378AAB.cnf.xml
235 -rw- 1880 SIPDefault.cnf
238 -rw- 3613 softkeyDefault.xml
239 -rw- 3579 softkeyDefault_kpml.xml
236 -rw- 69 syncinfo.xml
This is the configuration file it downloads as well.
-nick
ccievoice007 Fri, 01/23/2009 - 11:25
I'm using 22T.
The voice register creates SIPxxx.cnf files for the 7960 and SEPxxx.cnf.xml files for the 7962.
Neither the 7960 nor the 7962 re-registers with the authorization header in reponse to a 401 unauthorized msg from the CME.
I have a 3rd party software client that does include the authorization header and registers fine.
Within the Cisco phones is there a flag within the cnf file that need to be set? Or should the phones be setup with authentication and encryption before it can register using the digest authorization within SIP...
Nicholas Matthews Fri, 01/23/2009 - 11:39
I've found that if you have a pre-existing DN on the IP phone, it helps if you either delete that on the phone, or change it to the DN you're trying to register.
The same goes for any passwords you have configured on the phones.
There isn't a flag, other than the field existing that I know of.
-nick
