Backup Interface
Dec 22nd, 2008
Hello All
Maybe a easy one but I need to ask :)
I have 2 Leased Lines on 2811.
One of them will be a backup data line.
(for example serial 0 and serial 1
Serial 1 will be a backup data line)
Where should I put backup interface command and how ?
Thx for helping
Ersin
Overall Rating: 5 (1 ratings)
passioncas Mon, 12/22/2008 - 23:25
Go to interface Serial 1 and issue the command -if)# backup interface serial 0
Giuseppe Larosa Tue, 12/23/2008 - 04:01
Hello Rahul,
It should be the opposite
int ser 0
backup interface ser1
Hope to help
Giuseppe
passioncas Tue, 12/23/2008 - 04:05
Hello Giuseppe ,
You are right ..
Thanks for the update
Rahul
