Anyway to use RME to "reload" a device
Answered Question
Dec 22nd, 2008
The telnet port is not accessible (too many logins, no timeout value set.) Is there a way to issue the relo command with RME with snmp strings. I tried to do a netconfig job, but it failed because telnet enable was denied. Any other ideas?
Correct Answer by Joe Clarke about 8 years 6 months ago
RME 4.1 and higher have a Netconfig reload template which will work over SNMP. If you don't have RME 4.1, you can do an SNMP Set operation and set tsMsgSend.0 (1.3.6.1.4.1.9.2.9.9.0) to 2. This requires that you have already configured "snmp-server system-shutdown" though.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 12/22/2008 - 10:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
