CCC to MPE upgrade; import ccc meetings not working.
Dec 22nd, 2008
I trying to use the cccexport utility to move from ccc to mpe.
I purged all past meetings in ccc, up to the current day. It seems the export run successfully.
I run the import for ccc in mpe and get error messages about past meetings and duplicate meeting IDs, nothing imports.
I look through the .csv files and I can't find the indicated errors.
Has anyone successfully used the cccexport tool and can offer advice?
Anonymous (not verified) Mon, 12/29/2008 - 09:23
You are attempting to import the same file over again. You are trying to import both the Scheduled and Repeat meetings.
Repeat meeting is also listed in the scheduled meeting table with a flag. So when it is importing the scheduled table, it processes these records too and then figured out they are not the right ones.
It seems that you attempted to import scheduled meetings while there is no single future meeting to be imported. All you have are the repeated meetings.
