Change telnet password on ASA
Dec 22nd, 2008
On my ASA if I SSH to it I can put the same username and password I use when I use the ASDM, however when I tlenet to the ASA it just says password, I simply put in "password" and it lets me, then asks for my username and password, how do I change this first telnet password?
Overall Rating: 4 (1 ratings)
John Blakley Mon, 12/22/2008 - 14:09
  • Purple, 4500 points or more
Your telnet line pulls from the enable password if you don't have AAA authentication enabled. You can change the password with:
enable secret
HTH,
John
I disagree :)..
For your password, you need to enter this
ASA(config)#passwd your_telnet_password
annd one john said, to change the enable commmand, you need to enter
ASA(config)#enable password your_enable_password
Enable password in ASA is equivilant to enable secret in router/switches. There is no enable secret in ASA.
pls rate if helpful.
regards,
Mohsin
whiteford Tue, 12/23/2008 - 00:58
I managed to change the password.
What is confusing (could AAA be enabled):
1.) If I login via telnet I get prompted for a password which I enter, then I get to the user mode (I think) and then type enable and it have to enter my priviliged 15 username and password which I use for the ASDM or SSH.
2.) If I login via SSH I have to enter my level 15 username and password, then when I type enable I have to put my level 15 password in again and not the enable secret password I use in telnet.
All this sound normal?
John Blakley Tue, 12/23/2008 - 03:39
For the record, I was wrong. :-) Mohsin was right about passwd changing the telnet password. As for the other, can you post the config? It doesn't make sense.
HTH,
John
