WAAS and SNMP access-list
Dec 22nd, 2008
I am using 4.1.1c(build b16), and testing restricting access to the SNMP MIBS. we are running inline with a separate interface for mgmt. (gi1/0). with snmp access-list defined and snmp-server access-list set.
snmp-server community public
snmp-server access-list SNMP
ip access-list standard SNMP
permit 10.10.10.2
when i walk the mib from 10.10.10.2, and then look at ACL, it doesn't show any access.
CM#sh ip access-list SNMP
Standard IP access list SNMP
1 permit 10.10.10.2
(implicit deny any: 0 matches)
total invocations: 0
Overall Rating: 5 (1 ratings)
didyap Tue, 12/30/2008 - 05:46
  • Silver, 250 points or more
To define an IP ACL from the CLI, you can use the ip access-list global configuration command, and to apply the IP ACL to an interface on the WAAS device, you can use the ip access-group interface configuration command. To configure the use of an IP ACL for SNMP, you can use the snmp-server access-list global configuration command. To specify an IP ACL that the WAE applies to the inbound WCCP GRE encapsulated traffic that it receives, you can use the wccp access-list global configuration command.
