Impossible to notify by mail a Job.
Dec 22nd, 2008
Allthoug I configured an valid email adresse , the LMS cannot send the mail.
I just configured the IP-adresse of the smtp serveur in the server-preference parameters.
Is there anathing else to check ?
Note: if I telnet the ip_add-server-smtp with port 25 , I cannot connect .
Note : the server LMS is installed on an esx virtual system.
Thanks in advance.
Jason Fraioli Mon, 12/22/2008 - 12:52
Check that you are allowed to connect and relay through the SMTP server. If it is a Windows SMTP server, you'll need to check the SMTP Server in IIS.
Make sure to allow the LMS IP to connect and to relay.
