Skip phones in a hunt group CCM 4.0
j98me2
Is there a way to skip phones in a hunt group if people are not in the office in version 4.0?
Cisco CallManager Extension Mobility
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_0_1/ccmfeat/fsem.html
a little proactivity is good practice, all the info is on CCO if you search for it
java
if this helps, please rate
java
8 Replies 8
Jaime Valencia
depending on the exact version you could use the hlog feature or use EM
java
java
The exact version is 4.0(2a)sr1a
How would I go about doing it?
only option would be to try use EM as members, when not on office logout
java
java
I guess I am not sure what you mean by EM?
Sorry
extension mobility
java
java
Where do I find that at?
java
java
I started there. Sometimes the problem is to much information on there. Thanks for the help and the link.
