PS3 associate with UC520W Wifi
Dec 22nd, 2008
Recently I come this weird error when PS3 connect to UC520W Wifi.
PS3 version 2.53
UC520W IOS 12.4(22)T
Does anyone know what causing this and how can I solve it ?
000193: Dec 22 23:14:23.151: %DOT11-7-AUTH_FAILED: Station 00XX.XXXX.XXXX Authentication failed
000194: Dec 22 23:14:24.835: %DOT11-6-ASSOC: Interface Dot11Radio0/5/0, Station 00XX.XXXX.XXXX Associated SSID[MYSSID] AUTH_TYPE[OPEN] KEY_MGMT[WPAv2 PSK]
000195: Dec 22 23:14:34.659: %IP_VFR-3-SYSTEM_ERROR: BVI1: IP VFR System failure - Unable to create fragment chain
000196: Dec 22 23:14:34.659: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=853CDAD0, count=0, -Traceback= 0x80F1D668 0x80205388 0x81D03BE8 0x81D04A40 0x81D05608 0x81D06EA8 0x813638F4 0x80B5F20C 0x80B5F36C 0x802750A0 0x8091BB44 0x8091F37C 0x80906F70 0x809D6C58 0x801AC224 0x80026588
000197: Dec 22 23:14:34.659: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=853D7A48, count=0, -Traceback= 0x80F1D668 0x80205388 0x8026A110 0x80B5F1D4 0x80B5F36C 0x802750A0 0x8091BB44 0x8091F37C 0x80906F70 0x809D6C58 0x801AC224 0x80026588 0x80026588 0x801AC2E4 0x801ADC20 0x801ADECC
000198: Dec 22 23:14:34.759: %IP_VFR-3-SYSTEM_ERROR: BVI1: IP VFR System failure - Unable to create fragment chain
000199: Dec 22 23:14:34.759: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=853DB33C, count=0, -Traceback= 0x80F1D668 0x80205388 0x81D03BE8 0x81D04A40 0x81D05608 0x81D06EA8 0x813638F4 0x80B5F20C 0x80B5F36C 0x802750A0 0x8091BB44 0x8091F37C 0x80906F70 0x809D6C58 0x801AC224 0x80026588
000200: Dec 22 23:14:34.759: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=853D1790, count=0, -Traceback= 0x80F1D668 0x80205388 0x8026A110 0x80B5F1D4 0x80B5F36C 0x802750A0 0x8091BB44 0x8091F37C 0x80906F70 0x809D6C58 0x801AC224 0x80026588 0x80026588 0x801AC2E4 0x801ADE28 0x801ADDB8
000201: Dec 22 23:14:34.963: %IP_VFR-3-SYSTEM_ERROR: BVI1: IP VFR System failure - Unable to create fragment chain
000202: Dec 22 23:14:34.963: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=853C4E54, count=0, -Traceback= 0x80F1D668 0x80205388 0x81D03BE8 0x81D04A40 0x81D05608 0x81D06EA8 0x813638F4 0x80B5F20C 0x80B5F36C 0x802750A0 0x8091BB44 0x8091F37C 0x80906F70 0x809D6C58 0x801AC224 0x80026588
000203: Dec 22 23:14:34.963: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=853C7BE4, count=0, -Traceback= 0x80F1D668 0x80205388 0x8026A110 0x80B5F1D4 0x80B5F36C 0x802750A0 0x8091BB44 0x8091F37C 0x80906F70 0x809D6C58 0x801AC224 0x80026588 0x80026588 0x801AC2E4 0x8230B09C
000204: Dec 22 23:14:35.367: %IP_VFR-3-SYSTEM_ERROR: BVI1: IP VFR System failure - Unable to create fragment chain
000205: Dec 22 23:14:35.367: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=853C744C, count=0, -Traceback= 0x80F1D668 0x80205388 0x81D03BE8 0x81D04A40 0x81D05608 0x81D06EA8 0x813638F4 0x80B5F20C 0x80B5F36C 0x802750A0 0x8091BB44 0x8091F37C 0x80906F70 0x809D6C58 0x801AC224 0x80026588
000206: Dec 22 23:14:35.367: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=853C59B8, count=0, -Traceback= 0x80F1D668 0x80205388 0x8026A110 0x80B5F1D4 0x80B5F36C 0x802750A0 0x8091BB44 0x8091F37C 0x80906F70 0x809D6C58 0x801AC224 0x80026588 0x80026588 0x801AC2E4 0x801AFB44
000222: Dec 22 23:14:53.591: %DOT11-6-DISASSOC: Interface Dot11Radio0/5/0, Deauthenticating Station 00XX.XXXX.XXXX Reason: Sending station has left the BSS SSID[MYSSID]
Scott Fella Mon, 12/22/2008 - 19:17
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Try setting up wpa-psk w/ tkip and see if that works.
Gerald Chong Wed, 12/24/2008 - 00:38
No luck. still the same. Look like this maybe the PS3 firmware issue.
dennischolmes Wed, 12/24/2008 - 16:39
  • Gold, 750 points or more
Use nothing for encryption with mac filter and see if you can associate. Then move up to static wep. The PS probably doesn't respond quick enough for your controller. You might increase EAP timeouts from the cli.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
