BGP EIGRP race condition?
Dec 22nd, 2008
Hi all,
I'm not sure if my problem is because of a race-condition or not.
I have a head-office that can access a data center via metro ethernet or a MPLS circuit. For all network traffic to from the head-office, the metro ethernet is preferred.
If the metro ethernet fails, the MPLS DS3 will access the data-center via that connection as well as other sites.
We're redistributing BGP into EIGRP, but we're only redistributiing 'connected' into BGP. EIGRP is not being redistrbuted. (Check out the configs below). My problem is that some of the BGP routes are being overridden by the EIGRP routes. But it only seems to be routers with an Origin of (i) IGP that get overridden.
I copied my config from the router with the EIGRP routes in the routing table instead of BGP.
! This is the Chicago router.
interface GigabitEthernet0/0
ip address 172.28.10.113 255.255.255.252 secondary
ip address 10.77.226.53 255.255.255.240
duplex full
speed 100
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial1/0
bandwidth 44210
no ip address
encapsulation frame-relay IETF
dsu bandwidth 44210
frame-relay lmi-type cisco
interface Serial1/0.100 point-to-point
description MPLS Circuit
ip address 152.176.47.202 255.255.255.252
frame-relay interface-dlci 100 IETF
router eigrp 333
redistribute bgp 65028 metric 1536 700 255 1 1500 route-map block-aggregate
network 10.77.226.48 0.0.0.15
auto-summary
router bgp 65028
no synchronization
bgp log-neighbor-changes
network 172.22.0.0 mask 255.254.0.0
network 192.168.168.0 mask 255.255.254.0
redistribute connected
neighbor 152.176.47.201 remote-as 65000
neighbor 152.176.47.201 advertisement-interval 0
neighbor 152.176.47.201 route-map denyChicagoRoutes in
no auto-summary
ip route 172.22.0.0 255.254.0.0 Null0
ip route 192.168.168.0 255.255.254.0 Null0
ip access-list standard DenyAggregate
permit 172.22.0.0 0.1.255.255
permit 192.168.168.0 0.0.1.255
ip access-list standard DenyChicagoRoutes
permit 172.22.0.0 0.0.255.255
permit 172.23.0.0 0.0.255.255
permit 192.168.168.0 0.0.0.255
route-map block-aggregate deny 10
match ip address DenyAggregate
route-map block-aggregate permit 20
route-map denyChicagoRoutes deny 10
match ip address DenyChicagoRoutes
route-map denyChicagoRoutes permit 20
As always, thanks for the help.
Mike
Overall Rating: 3 (1 ratings)
tomek0001 Mon, 12/22/2008 - 19:09
Mike
Can display the output of
"show ip route"
"show ip bgp"
and for the routes you see overwritten by eigrp
"show ip bgp x.x.x.x"
That would be easier to troubleshoot. Without that information I would check if you don't have the same routes in EIGRP and iBGP, sine the administrative distance of EIGRP (90) will win over iBGP (200).
(please rate if helpful)
msrohman Tue, 12/23/2008 - 08:07
Thanks for taking a look. I attached a network diagram too.
I used an example from the San Francisco site. The 10.10.3.0/24 network should be in the routing table via BGP, but it's not.
The other MPLS sites have all of the San Francisco routes in the BGP table and IP routing table.
I attached the output to this message.
tomek0001 Tue, 12/23/2008 - 10:34
Mike
Base on this
wwacker2-1103009>sh ip route
D EX 10.10.3.0/24 [170/87808] via 10.77.226.51, 2d16h, GigabitEthernet0/0
[170/87808] via 10.77.226.50, 2d16h, GigabitEthernet0/0
I would follow the source of 10.10.3.0/24 advertisement to EIGRP. From your output I can see that the next step is your two routers 10.77.226.51 and .50. Go to these see what they say for the same route (sh ip route 10.10.3.0) if they are learning it from EIGRP from another rotuer follow it until you reach the first point of advertisment of that route into EIGRP. You can post the config from that router or check out how that route gets to EIGRP.
/hope that helps, please rate if helpful.
Tom
tomek0001 Tue, 12/23/2008 - 10:45
hmm. just thought of something else.
Check out what the router peering with onuv-wwacker2-1103009 is advertising to you
sh ip bgp neighbors 152.176.47.201 advertised-routes
see if you see the 10.10.3.0/24. If not that's another way to troubleshoot. I am thinking that if that was advertised to that router you would get it through eBGP and not through EIGRP coming from your Downer Grove site.
Check that out.
Tom
sdoremus33 Tue, 12/23/2008 - 12:51
  • Bronze, 100 points or more
Could you also post IP CEF 10.10.3.0 on onuv-wwacker2-1103009 ( Chicago router ). Thanks
msrohman Tue, 12/23/2008 - 13:16
wwacker2-1103009>sh ip bgp neighbors 152.176.47.201 advertised-routes
BGP table version is 3345, local router ID is 152.176.47.202
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 10.77.226.48/28 0.0.0.0 0 32768 ?
*> 152.176.47.200/30
0.0.0.0 0 32768 ?
*> 172.22.0.0/15 0.0.0.0 0 32768 i
*> 172.28.10.112/30 0.0.0.0 0 32768 ?
*> 192.168.168.0/23 0.0.0.0 0 32768 i
Total number of prefixes 5
This is what I'm advertising to the EBGP neighbor.
I'm not allowed to perform the following:
wwacker2-1103009>sh ip bgp neigh 152.176.47.201 received-routes
% Inbound soft reconfiguration not enabled on 152.176.47.201
-wwacker2-1103009>sh ip cef 10.10.3.0
10.10.3.0/24, version 1025, epoch 0, per-destination sharing
0 packets, 0 bytes
via 10.77.226.51, GigabitEthernet0/0, 0 dependencies
traffic share 1
next hop 10.77.226.51, GigabitEthernet0/0
valid adjacency
via 10.77.226.50, GigabitEthernet0/0, 0 dependencies
traffic share 1
next hop 10.77.226.50, GigabitEthernet0/0
valid adjacency
0 packets, 0 bytes switched through the prefix
tmstats: external 0 packets, 0 bytes
internal 0 packets, 0 bytes
tomek0001 Tue, 12/23/2008 - 19:36
based on all of this i would say you check 152.176.47.201 and if what routes you have there. if 10.10.3.0 is there and it being send to 152.176.47.202. otherwise follow this route and find the source of 10.10.3.0 advertisement into EIGRP.
What is the routing table at 152.176.47.201?
Where does 10.10.3.0 originate advertisement to EIGRP?
msrohman Thu, 12/25/2008 - 19:39
Thanks. I'm going to have oru provider check the routing and BGP tables on their pier. I opened a ticket a few days ago.
The 10.10.3.0/24 route is getting redistributed from the other Illinois MPLS connection. It's the primary route, but the wacker router should be receiving BGP routes.
-Mike
-Mike
