Unable to telnet the cisco 2900
Dec 22nd, 2008
I am trying to telnet to cisco 2900 switch. I believe there is a VTY password configured. When I give the pasword. I am getting the below error.
"Local flow control off"
"User Access Verification
Password: Connection closed by foreign host."
Appreciate you help help.
Thanks & Regards
Ranga
Ranga_Goud Mon, 12/22/2008 - 21:36
I am at remote place. I tried doing access thru HTTP also , no luck. Is there any way that I can login to switch and verify the configuration.
ohassairi Mon, 12/22/2008 - 21:55
you need to find a bug in web access to this switch.
the message you get, i think it is due to an access-list on telnet: only one pc can telnet to the switch. may be the management station, if you have one.
Ranga_Goud Mon, 12/22/2008 - 22:50
Thanks for response. We does have acces to only from one machine in the network. And I got the configuration that is in backup server. Here is the configuration of login access. I believe with the below configuration might be same problem when we console the switch.
Line-Line con 0
line con 0
session-timeout 15
password*****
no vacant-message
login
transport input none
stopbits 1
Line-Line vty 0 4
line vty 0 4
session-timeout 15
access-class XX in
exec-timeout 15 0
password*****
no vacant-message
login
Line-Line vty 5 15
line vty 5 15
access-class XX in
login
ohassairi Tue, 12/23/2008 - 01:35
in console we can't define an access list, so you only need to know the password.
but under telnet, you do have an access list. you can only telnet fron that station
