Dynamips, Is it sufficient?
Dec 22nd, 2008
Hi There,
Can someone suggest if Dynamips alone can be used to practice all R/S lab LAN switching topics or it needs to be integrated with external 3550s/3560s?
Thanks for your time!
Danilo Dy Tue, 12/23/2008 - 00:57
Dynamips is good enough, unless you really want to messed around with cables (and have the $$$ to purchase a router/switch and isdn/frame-relay switch box).
Do take note that Dynamips support switching module (which can be use instead of 3550/3560). Following router model that Dynamips support with switching module are;
3620
3640
3660
2691
3725
3745
2600
***Just need to get the right IOS.
http://www.ipflow.utc.fr/index.php/Cisco_7200_Simulator
tech_peer Tue, 12/23/2008 - 04:41
Hi There,
Thanks for the input. I will give it shot with Ethernet SW modules on one of supported platform. Hope can test everything using these modules cause would like to avoid purchasing 3550s/3560s. Thanks for your time.
Danilo Dy Sun, 12/28/2008 - 21:21
You can do your practice with Dynamips.
However, for the final exam preparation, I suggest for you to invest in workbook and online rack-time (setup according to the workbook). There are training centers that sells workbooks and online rack-time.
paul_alexander Tue, 12/23/2008 - 04:55
I used dynamips for 95% of my ccie studies.
In theory you could use it solely for passing the exam but its a little risky. I would reccomend investing in a little rack time to get familiar with all the switch features.
Fraser Reid Mon, 02/01/2010 - 01:49
I would like to get real 3560's (I have 4) added to a dynamips Net config - can anyone out there help me ?
