duplicated ip on a vlan
Dec 23rd, 2008
i have a wireless lan with wlc.
the wlc has some vlans, also 1 vlan which is the same of the wired lan.
if i connect to the wlan 1 get a message of duplicated ip even if i get an ip that is no used by any host.
can anyone help me?
rnigam Wed, 12/24/2008 - 13:08
where have you configured the DHCP server? Do you have two configuration settings of DHCP on your network. Is internal DHCP also configured.
Scott Fella Fri, 12/26/2008 - 07:47
Also where do you see the duplicate ip address.... on the client or on the switch log? If the message on the switch is a duplicate address of one of the interfaces, then look at your configuration on the wlc. How is your wirless setup...
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
