Secure VPN Connection terminated locally by the Client. Check your network
Dec 23rd, 2008
Hi!!!
Shortly topology: ASA 5510, clients connected on dialup using Cisco VPN Client. Connection is adjusted automatically, i.e. Windows XP starts VPN Client, it in turn starts dialup connection. And so a problem essence: At breakage dialup connections, VPN Client connection with an error: "Secure VPN Connection terminated locally by the Client. Check your network connection."
And I do not see a way to force VPN Client to be connected automatically again.
Thanks big in advance!
vmoopeung Mon, 12/29/2008 - 08:01
  • Bronze, 100 points or more
If the Ethernet interface loses link during a VPN Client connection, the following bogus error message appears:
Secure VPN Connection terminated locally by the Client Reason: An unrecognized error occurred while establishing the VPN connection. This message should indicate you have lost a connection with the peer.
