can not access fxo in 2611XM
lorcs
I have a 2611XM with NM-2V and Vic-2xo module. The router runs advance enterprise feature 12.4-21a. The router is able to recognize both NM-2V and Vic-2FXO module but I can not access the voice-port interface mode to configure the FXO. Is there any command I can type to activate the FXO ? Or is there any other problems? I have tried different IOS and the result is the same. Here is the show diag for your reference:
Slot 1:
4 PORT Voice PM for C2600 Port adapter
Port adapter is analyzed
Port adapter insertion time 1w5d ago
EEPROM contents at hardware discovery:
Hardware revision 1.1 Board revision H0
Serial number 24256275 Part number 800-02491-02
FRU Part Number NM-2V=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x00: 01 65 01 01 01 72 1F 13 50 09 BB 02 00 00 00 00
0x10: 88 00 00 00 01 01 03 17 FF FF FF FF FF FF FF FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF
VIC Slot 1:
FXO Voice daughter card (2 port)
Hardware revision 1.1 Board revision K0
Serial number 29226198 Part number 800-02495-01
Connector type Wan Module
0x20: 01 0D 01 01 01 BD F4 D6 50 09 BF 01 00 00 00 00
0x30: A0 00 00 00 02 09 24 01 FF FF FF FF FF FF FF FF
Rob Huffman
Hi Chun,
It sounds like you do not have any DSP resources.You will need something like a PVDM2-8 card on the motherboard to provide DSP resources to the FXO card. Without DSP resources you cannot configure the FXO :)
Here is a link to the DSP Calculator
http://www.cisco.com/cgi-bin/Support/DSP/cisco_prodsel.pl
Hope this helps!
Rob
