Broken cable for 7937 mics
Dec 23rd, 2008
I have a set of mics for the 7937 conference IP phone, however someone has pulled the cable of the mic and the end connection is no lying in bits. Does anyone know what kind of cable this is? It is slightly smaller than an USB connection, with two corners rounded off and there are 7 pins inside it. I've tried to use google but to no avail - any help appreciated!
Overall Rating: 5 (3 ratings)
Rob Huffman Tue, 12/23/2008 - 05:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Sarah,
The Cisco 7937 is a re-branded Polycom Soundstation 7000. If you Google these two part #s you will find lots of hits for the replacement mic kit cables (pretty cheap as well :)
polycom 2200-40017-001 for 7 footer
polycom 2200-40017-003 for 25 footer
Here is a picture of the Polycom Soundstation 7000;
http://www.polycom.com/usa/en/products/voice/conferencing_solutions/conference_phones/soundstation/soundstation_ip7000.html
Hope this helps! Happy Holidays!
Rob
