AAA --> Int range configuration gives "Command authorization failed" msg.
Dec 23rd, 2008
Versions involved:
AAA
ACS 4.1.4.13.12
Devices:
C2960-LANBASE-M, Version 12.2(25)SEE3, RELEASE SOFTWARE (fc2)
C3550-I9Q3L2-M, Version 12.1(14)EA1a, RELEASE SOFTWARE (fc1)
If we try to configure a single interface or just a very small range, it works fine, but if we try to configure a larger range of interfaces, we get a Command authorization failed message, as can be seen below:
HOST1184(config)#int range fastEthernet 0/1 - 3
HOST1184(config-if-range)# switchport access vlan 24
HOST1184(config-if-range)# switchport mode access
HOST1184(config-if-range)# switchport voice vlan 301
HOST1184(config-if-range)# dot1x pae authenticator
HOST1184(config-if-range)# dot1x port-control auto
HOST1184(config-if-range)# dot1x timeout reauth-period 7200
HOST1184(config-if-range)# dot1x timeout supp-timeout 120
HOST1184(config-if-range)# dot1x max-req 1
HOST1184(config-if-range)# dot1x max-reauth-req 1
HOST1184(config-if-range)# dot1x reauthentication
HOST1184(config-if-range)# dot1x guest-vlan 280
HOST1184(config-if-range)# spanning-tree portfast
HOST1184(config-if-range)#!
OST1184(config-if-range)#end
HOST1184#conf t
Enter configuration commands, one per line. End with CNTL/Z.
HOST1184(config)#int range fastEthernet 0/4 - 14
Command authorization failed.
The pieces of config are as follows:
aaa new-model
aaa group server radius dot1x
server 10.61.156.136 auth-port 1812 acct-port 1813
aaa authentication login default group tacacs+ enable
aaa authentication enable default group tacacs+ enable
aaa authentication dot1x default group dot1x
aaa authorization config-commands
aaa authorization exec default group tacacs+ if-authenticated none
aaa authorization commands 0 default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
enable secret 5 <removed>
logging 10.142.4.45
snmp-server community <removed> RO
snmp-server community <removed> RW
snmp-server location "SD"
snmp-server contact contact - [email protected]
tacacs-server host A.B.C.D timeout 5 key <removed>
no tacacs-server directed-request
radius-server host 10.61.156.136 auth-port 1812 acct-port 1813 key 7 096E5C3D4851
radius-server retransmit 3
Anyone out there has a solution for such a problem?
AL
Jagdeep Gambhir Tue, 12/23/2008 - 06:08
  • Red, 2250 points or more
Al,
Please check your acs shell command autho settings. You may need to permit range command in it.
~JG
Do rate helpful posts
alvaro.motta Tue, 12/23/2008 - 08:37
Hi JG, thanks for your response.
I don't have the appliance close to me, so I cannot check on this setting.
As soon as I have a chance, I will return with this info.
Anyway, why does it work for other devices and also, why we don't have any problem when configuring a small range of interfaces?
Once again, thanks for your reply.
AL
Jagdeep Gambhir Tue, 12/23/2008 - 12:11
Some IOS ver send different syntax to acs for command authorization.
~JG
