Progress ind. No ringtone
Dec 23rd, 2008
Hi Guys,
I having a problem calling one of our sites. The calls are going via our MPLS using the Carriers PGW network. The calls are being set up and are connecting but when we call the Tokyo office the caller dosen't get and ringtone back. The user in Tokyo does hear ting tone when they make a call to us. We are using a H323 gateway Cisco 2821 running (C2800NM-SPSERVICESK9-M), Version 12.3(8)T4. We use a 7 digit dial plan, 3 site code + 4 local extension. Tokyo's site code is 745. All these call go out of serial 1/1 and are using dial-peer voice 2 pots.
Can anyone spot a mistake in the config?
I have done a couple of debugs attached and found that the Progress Ind i = 0x8088 is not being sent.
________________________________________
TOKYO_10_2821_1#show run
Building configuration...
Current configuration : 5683 bytes
card type t1 1 1
clock timezone gmt 9
clock summer-time AT recurring
network-clock-participate slot 1
no network-clock-participate aim 0
no network-clock-participate aim 1
network-clock-select 1 T1 1/0
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
isdn switch-type primary-ntt
voice-card 0
no dspfarm
voice-card 1
no dspfarm
voice class codec 1
codec preference 1 g711alaw
ccm-manager music-on-hold
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24
description **** To NTT PSTN Q931 PRI ****
controller T1 1/1
framing sf
clock source internal
linecode ami
pri-group timeslots 1-8,24
description **** To Internal network QSIG PRI ****
interface Serial1/0:23
no ip address
isdn incoming-voice voice
no cdp enable
interface Serial1/1:23
no ip address
no cdp enable
control-plane
voice-port 1/0:23
cptone JP
voice-port 1/1:23
mgcp
mgcp call-agent 10.158.95.18 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Loopback1
mgcp profile default
dial-peer voice 1 pots
description Outgoing_From_PSTN
destination-pattern T
no digit-strip
direct-inward-dial
port 1/0:23
forward-digits all
destination-pattern 7T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
no digit-strip
direct-inward-dial
port 1/1:23
forward-digits all
dial-peer voice 5000 voip
destination-pattern 745T
session target ipv4: x.x.x.x
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 5002 voip
destination-pattern 1...
codec g711ulaw
dial-peer voice 12344 voip
description Incoming_From_PSTN
preference 1
destination-pattern 6212....
codec g711ulaw
dial-peer voice 12345 voip
preference 2
session target ipv4:10.158.95.18
codec g711ulaw
dial-peer voice 3 pots
tone ringback alert-no-PI
destination-pattern 7480
progress_ind setup enable 3
no digit-strip
direct-inward-dial
port 1/1:23
forward-digits all
dial-peer voice 4 pots
destination-pattern 748....
no digit-strip
direct-inward-dial
port 1/1:23
forward-digits all
