GigabitEthernet0/52 is down, line protocol is down (err-disabled)
Dec 23rd, 2008
I have problem with g0/52 in 3560 switch
IT_SW1_3560#show interfaces gigabitEthernet 0/52
This port has gibic
And I write show errordisble recovery the reson is Err disable reason gibic-invalid
I need to solve this problem
glen.grant Tue, 12/23/2008 - 05:30
  • Purple, 4500 points or more
Cisco devices are very fussy about using non cisco gbics. If you are using a non cisco gbic then that is probably the problem . You would have to get a cisco gbic to get around this even though they can be considerably more expensive. If its a cisco gbic get it rma'd from cisco. Try doing a "shut" then no shut and see if it comes active.
glen.grant Tue, 12/23/2008 - 05:49
Get the gbic replaced.
ahmed_saleh Tue, 12/23/2008 - 05:58
1- i rebleaced the gbic
same error
2- this switch have 4 ports gbic and tray to change from on port is arady runing and but it in this port i have the err disable
bilousand Tue, 12/23/2008 - 05:57
There are some old GBICs marked as cisco which do not work with newer IOS. I have had to replace some after migration from 11 to 12 IOS train.
You can try hidden IOS command in order to make them work.
Router(config)#service unsupported-transceiver
