impossible to launch topology service from Camp. Manager module
Dec 23rd, 2008
I have a LMS 3.1
If I clic "topology service" from campus-manager-module on the lms-server itself:
- I have the message "do you want to save this file?
- I clic Yes
- And Nothing happens.
Note , before I installed java 1.605 as lms asked me to do.
To launch topology service , I need to double-clic the file "topology-service.jnlp". In this way, it works.
Is-it normal ?
Thanks in advance for your quick response
Joe Clarke Tue, 12/23/2008 - 10:00
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes and no. This issue is typically browser-related. It means you have changed the handling of the JNLP files. You can play with file types in your browser config to get JNLP files to auto-launch. However, some customers have found it easier to create a new, clean account as they were unable to get the JNLP files to auto-launch.
