CSM integration with CSA : Error: Failed to import file
Dec 23rd, 2008
I use CSA5.1 rev108 and CSM3.2.1 in my LAN.
The CSM installation guide says to import the file CSMCSA3.2.0_policies.export so that there is no more config to implement.
But the proble is that when CSA import the list, then CSA sais that there is an error :
Importing objects, please wait ... . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Error: Unexpected element (APPCLASS_TARGET_REF) found under element RULE
Is there any issue?
Where can I get this file from Cisco?
Is there any link?
Best regards
