Stop CSA agent
Dec 23rd, 2008
I Have a doubt, I have the csa agent blocked with the function "Base - CSA Service and client UI control" (disable), but I cant stop the agent in the host,
the command -net stop csagent- works in this case, or I need first enable the "Base - CSA Service and client UI control".
thanks
Overall Rating: 5 (2 ratings)
matt_nels Tue, 12/23/2008 - 14:23
Yes. In order to disable the agent, you will need to check the box. If you want to stop people from disabling the agent, uncheck the box.
tsteger1 Sun, 12/28/2008 - 23:40
  • Red, 2250 points or more
Matt is right on. Use Agent UI and Agent Service Control rules to allow or deny all agent modification.
Tom
