How do you connect to an ASA 5505 ?
Answered Question
Dec 23rd, 2008
I have tried by putting https://192.168.1.1 into my browser, and that gets me to a screen where I can install a launcher, run a settup wizard or run an applet.
I have installed the launcher. It asks for the IP, username and password. Following section 5 in the manual I give it an IP of 192.168.1.1 and leave the username and password blank.
After a long wait I get "permission denied." I have managed to get in with the blue cable in Com1 and created a password, but I still get the same result from the browser.
When I try it with either the applet or the wizard I get "error. Click for details". The details consists of this:
load: class com.cisco.nm.dice.loader.Loader not found.
java.lang.ClassNotFoundException: com.cisco.nm.dice.loader.Loader
at sun.applet.AppletClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadCode(Unknown Source)
at sun.applet.AppletPanel.createApplet(Unknown Source)
at sun.plugin.AppletViewer.createApplet(Unknown Source)
at sun.applet.AppletPanel.runLoader(Unknown Source)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
I would be glad to set it up with the blue cable, but I cannot find a list of commands.
I did at one point find an opportunity to reset it to defaults, but it didn't work. The reset hole in the front doesn't work either.
Where can I find a command reference for it ?
Correct Answer by John Blakley about 8 years 3 months ago
That's odd. I'm running version 6 update 7, and it works fine for me. What do you have listed in Windows Add/Remove Programs?
Overall Rating: 4.8 (3 ratings)
John Blakley Tue, 12/23/2008 - 11:54
  • Purple, 4500 points or more
You're having a problem with java. It seems that ASDM only works well with certain versions. You may either want to downgrade or upgrade your java version.
HTH,
John
MyersEngineering.com Tue, 12/23/2008 - 12:04
How do I do downgrade or upgrade ?
Where can I find an older or newer version?
I have gone to sun.com, Downloads A-Z, and there is only one option for Windows.
John Blakley Tue, 12/23/2008 - 12:11
What version are you running now? You can tell by going to Control Panel/Java and then click on the About button. It should say what version, and then I can point you to the right direction (hopefully).
HTH,
John
MyersEngineering.com Tue, 12/23/2008 - 12:49
It was xpiinstall-6u11-fcs-bin-b90-windows-i586-25_nov_2008.exe
I uninstalled that and installed j2re-1_4_2_19-windows-i586-p.exe
Then I tried to get into the ASA 5500. It told me I needed to install a plugin, and when I clicked to let it, it started to put the same old 6u11 back again.
So if folks can downgrade, how do they do it? The only other version I can find on Sun's site is apparently so old that it isn't even recognozed as valid, and I am directed right back to what doesn't work.
Correct Answer
John Blakley Tue, 12/23/2008 - 13:00
MyersEngineering.com Tue, 12/23/2008 - 13:09
V1.4.2_19
And it isn't working, and I suspect you'll want to know what's in there after I reinstall the previous one. One moment please.
MyersEngineering.com Tue, 12/23/2008 - 13:20
OK, it is not Java(TM) 6 Update 11
And now when I try my launcher I get ASDM is unable to read the configurartion from the ASA ...
MyersEngineering.com Tue, 12/23/2008 - 13:23
So I tried it with the applet, ant IT WENT IN :)
Thank you very much. Have a merry Christmas.
And now I must go hack my way through the ice on my wife's car :(
John Blakley Tue, 12/23/2008 - 13:24
Great! Have a merry Christmas :-)
MyersEngineering.com Wed, 12/24/2008 - 04:59
And this morning, rereading yesterday's posts, where I said "OK, it is not Java 6 (TM), the w in not should have been a w in now. It is indeed Java 6 update 11. Sorry.
