ACE - SNMP to the alias IP address.
Dec 23rd, 2008
Hello
Does it work? Is it possible to poll the alias IP address in HA? I have tried and it does not seem to work. The moment I change to the interface IP at the management console, it starts working so the policy is ok. Any advice? If it is not possible, do we have to set up two managed devices for each context? I mean one for the active and one for the standby.
Thanks a lot.
Guido
Overall Rating: 5 (1 ratings)
Gilles Dufour Tue, 12/23/2008 - 14:32
The problem is that the response comes back from the physical ip address.
A new bug was opened for this and we are currently investigating : CSCsw67225
Gilles.
ggalteroo Mon, 12/29/2008 - 14:23
Ok, thank you. For the time being we will just use a second object at the mgmt station.
Guido
