Unable to change console speed on C2960 with set/unset BAUD
Dec 23rd, 2008
I have just recover my c2960 switch uploading IOS by xmodem. During the orocedure I changed the baud rate to 115200 to make faster, and now I am not able to change it. I tried unset BAUD, set BAUD 9600... anytime I reboot the switch is again with 115200.
In show run after rebooting appears
line console 0
speed 115200
I have changed it with speed command and save, but is appears again after reboot.
Any idea?
1 vote
viyuan700 Tue, 12/23/2008 - 13:38
check ur sh startup-config, what is the value ?If 9600 there.
Then ur switch configuration register is set to a value where it bypass the statupconfig file a boot.
ullasupendran Tue, 12/23/2008 - 14:09
Try changing your config-register value to 0x2101 or 0x2102.save it and restart. That will set the baud rate back to 9600.
"Pls Rate if it helps"
Ullas
loretomarquez Mon, 12/29/2008 - 03:21
Hi Viyuan,
My startup configuration was empty ¿? I retype again speed 9600 in line console 0, save and copy running into startup-config
With this, my startup configuration now is correct. I reloaded the switch and I still have 115200. I think the router doesn't chose the correct config file for booting.
Switch#dir
Directory of flash:/
2 -rwx 616 Mar 1 1993 00:43:58 +00:00 vlan.dat
3 -rwx 5 Mar 1 1993 00:06:23 +00:00 private-config.text
5 -rwx 4671232 Jan 1 1970 02:44:02 +00:00 c2960-lanbase-mz.122-2-25.SEE3.bin
7 -rwx 1905 Mar 1 1993 00:06:23 +00:00 config.text
621 drwx 192 Mar 1 1993 00:24:55 +00:00 c2960-lanbase-mz.122-25.FX
32514048 bytes total (22154752 bytes free)
Switch#show boot
BOOT path-list : flash:c2960-lanbase-mz.122-25.FX/c2960-lanbase-mz.122-25.FX.bin
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : yes
NVRAM/Config file
buffer size: 65536
Any idea?
glen.grant Mon, 12/29/2008 - 05:58
Whats does your config register say ? Do a show version and it will tell you what it is. If its not 0x2101 or 0x2102 then it is incorrect and you have to change it . Putting anything on the line console interface will not help. The register governs the console speed.
loretomarquez Mon, 12/29/2008 - 08:49
Hi Glen,
As you can see config register is 0xF. I hadn't change it, this is the factory value.
Switch#show version
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(25)FX, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 12-Oct-05 22:05 by yenanh
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(25r)SEE1, RELEASE SOFTWARE (fc1)
Switch uptime is 3 hours, 58 minutes
System image file is "flash:c2960-lanbase-mz.122-25.FX/c2960-lanbase-mz.122-25.FX.bin"
cisco WS-C2960-48TC-L (PowerPC405) processor (revision C0) with 61440K/4088K bytes of memory.
Processor board ID FOC1121ZDJE
Last reset from power-on
1 Virtual Ethernet interface
48 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1C:57:74:AA:80
Motherboard assembly number : 73-9835-07
Power supply part number : 341-0097-02
Motherboard serial number : FOC1121400G
Power supply serial number : DCA111486MQ
Model revision number : C0
Motherboard revision number : C0
Model number : WS-C2960-48TC-L
System serial number : FOC1121ZDJE
Top Assembly Part Number : 800-26672-02
Top Assembly Revision Number : D0
Version ID : V02
CLEI Code Number : COM3F00BRA
Hardware Board Revision Number : 0x02
Switch Ports Model SW Version SW Image
* 1 50 WS-C2960-48TC-L 12.2(25)FX C2960-LANBASE-M
Configuration register is 0xF
Switch#
viyuan700 Mon, 12/29/2008 - 07:13
An mentioned in other post ur configuration register looks like is 0x2142(can be something else) in this setting it dont read the startup-config.
YOu change to this value if you forgot the password and cannot login.
loretomarquez Mon, 12/29/2008 - 09:49
Yes I know what you mean I have use those values with other models for password recovery, but in this case the config register is 0xF which is normal in this model as I has been reading. You can see the show version in the answer I wrote before to glen.grant.
viyuan700 Mon, 12/29/2008 - 12:01
Your config file path has /,u can try without it like in flash path.
Though it doesnot make sense but sometimes i see problem when i include / in defining path.
loretomarquez Tue, 12/30/2008 - 03:56
I have another 2960 with the same path and everithing goes correct.
Anyway I tried by changing the path to
flash:c2960-lanbase-mz.122-2-25.SEE3.bin
and the problem persists. The load of the image is normal but I still can't change the console baud rate.
This is very strange. It must be something fixed before the load of the image.
loretomarquez Tue, 12/30/2008 - 06:29
:o) It works.
This is what I did:
-shutdown the switch
-press Mode button while power on the switch to enter in switch: mode.
-enter set command to see the BAUD=115200
-enter flash_init command
-now is the right moment to enter unset BAUD command
-continue booting the switch in my case with
boot flash:c2960-lanbase-mz.122-2-25.SEE3.bin
I have reloaded the switch several times after this and fortunately it remains with the correct bau rate.
Anyway thanks for your help.
normbeef Sun, 08/07/2011 - 13:11
This works for 3560's as well been driving me insane o my lab..
many thanks loretomarquez
You must be precise with the syntax
the command is    unset BAUD   from switch:
Peter Marshall Wed, 05/28/2014 - 05:39
Boot the switch in ROMMON
Change it in ROMMON (case sensitive):
set BAUD 9600
Reboot the switch.
