MPLS on 1700, ver 12.4
Dec 23rd, 2008
I cannot configure MPLS on a 1700 router. Version 12.4!!
I type in
IP CEF then go under each interface either s0/0 or e0/0 type
type in MPLS IP
it says command unrecognized. What am I doing wrong ?
I can't configure it from both Priveledged or global mode
Please help.
Overall Rating: 3 (1 ratings)
Edison Ortiz Tue, 12/23/2008 - 18:01
  • Hall of Fame,
    Founding Member
MPLS is not supported under the 1700 Router. You need an 1805/1841/1861 with 12.4T Release for MPLS support on those entry level routers.
HTH,
__
Edison.
sergeimavashev Tue, 12/23/2008 - 22:02
Are these the ONLY routers that support it 1805/1841/1861 with 12.4 ?? or there are other ones ?
Edison Ortiz Wed, 12/24/2008 - 06:24
  • Hall of Fame,
    Founding Member
Cisco has a big product line so I won't list every single router that support MPLS.
Best course of action for you is to check this website: http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp and Select "Search By Feature".
The intended feature is MPLS.
HTH,
__
Edison.
