Cisco Wii fi manager
prasad.gsmc
Dear All,
I need to manage all Cisco 1010, WLC 4402, AIR-LAP 1242AG. Is there any softare available with which I can do Monitoring (with alerts) and management of all these devices. Please help and thanks in advance.
5 Replies 5
Thanks for the quick reply. Is there any evaluation available for this software?
On the link that i sent earlier, click on "Download Software" and get the latest version.
Hi Prasad,
Just to add a touch to the good tips from Pari,
There is a 30 Day Demo license for the WCS.
This good doc should get you started;
This Cisco Wireless Control System (WCS) licensing and ordering guide presents ordering guidelines for new Cisco WCS SKUs and licensing information for existing Cisco WCS deployments that are being upgraded to support Cisco Unified Wireless Network Software Release 4.1. This guide includes information on buying new or expansion Cisco WCS licenses, migrating from CiscoWorks Wireless LAN Solution Engine (WLSE) to Cisco WCS, upgrading to the Cisco WCS Location option, and deploying the free Cisco WCS Demonstration License.
From this good doc;
http://www.cisco.com/en/US/products/ps6305/products_data_sheet0900aecd804b4646.html
To request the free Cisco WCS Demonstration License, visit
http://www.cisco.com/go/license or
https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet.
A free 30 day, full featured evaluation copy of WCS for 10 AP support can be downloaded on Cisco.com. Please note that you will be prompted to enter your contact information and the hostname of the WCS server you would like to install the license on so plan on having that information in front of you prior to the download. The download will then generate a license file that you will be emailed. Following are the instructions to download 30 day WCS evaluation software :
1). https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet.
2). Navigate to Network Mgmt Products
3). Look for Wireless Control System
** The WCS Demo Software is NOT supported by the Cisco Technical Assistance Center.
Hope this helps! Happy Holidays!
Rob
Make sure to use older code. 4.1.185 or older as it is the only code to manage the 1010s. They were removed from 4.2 and later versions of code.
