ASA5505 - Maximum VPN Clients
Answered Question
Dec 23rd, 2008
Hey all, any idea what the maximum number of VPN clients can connect to the ASA5505? It is running the base image. Thanks, robert.
Licensed features for this platform:
Maximum Physical Interfaces : 8
VLANs : 3, DMZ Restricted
Inside Hosts : Unlimited
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Enabled
VPN Peers : 10
WebVPN Peers : 2
Dual ISPs : Disabled
VLAN Trunk Ports : 0
This platform has a Base license.
Correct Answer by Farrukh Haroon about 8 years 2 months ago
Yes apparently your understanding is correct. If you have a box running you could lab this up and see what happens after the 11'th simulatenous client tried to connect. Most probably the client wil see an error message.
Please rate if helpful.
Farrukh
Overall Rating: 5 (2 ratings)
Robert Ho Wed, 12/24/2008 - 14:05
so, vpn "peers" and vpn "clients" are synonymous? if a small business with 25 employees has an asa5505, then no more than 10 employees can connect with the base license?
Correct Answer
Farrukh Haroon Wed, 12/24/2008 - 23:56
  • Red, 2250 points or more
Farrukh
Robert Ho Thu, 12/25/2008 - 00:13
Just to make sure, we can have unlimited user/pass accounts but only 10 can connect simultaneously?
Farrukh Haroon Thu, 12/25/2008 - 00:18
Yes Robert, this limit does not apply to usernames (either local or on a AAA server).
Farrukh
Robert Ho Wed, 12/24/2008 - 14:10
Farrukh, thanks for the link. It is exactly what we needed!
