NAT traffic between the IPsec VPN
Dec 24th, 2008
We are using a 515E firewall in which we are established VPN without Nating the Traffic between existing VPN
But Now we had some requirement to NAT the Trafic between the new VPN which we trying to esatblish can u pls suggest me how i can deploy NAT for the new tunnel with the below running config
the partial configuration is :
access-list 123 permit ip 10.88.0.0 255.255.0.0 host 192.168.151.32
access-list 123 permit ip 10.89.0.0 255.255.0.0 host 192.168.151.32
access-list 111 permit ip 10.88.0.0 255.255.0.0 host 192.168.151.32
access-list 111 permit ip 10.89.0.0 255.255.0.0 host 192.168.151.32
pager lines 24
logging on
logging console debugging
logging monitor debugging
logging buffered debugging
mtu outside 1500
mtu inside 1500
mtu dmz 1500
mtu gs-office 1500
mtu intf4 1500
mtu intf5 1500
ip address outside XX.137.0.50 255.255.255.240
ip address inside 10.101.21.20 255.255.255.0
ip address dmz XX.137.0.129 255.255.255.240
ip address gs-office 10.103.21.20 255.255.255.0
global (outside) 1 interface
nat (inside) 0 access-list 123
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
nat (dmz) 0 access-list 121
nat (dmz) 1 0.0.0.0 0.0.0.0 0 0
nat (gs-office) 1 access-list 151 0 0
route outside 0.0.0.0 0.0.0.0 83.137.0.49 1
route inside 10.0.0.0 255.0.0.0 10.101.21.1 1
route inside xx.1.1.0 255.255.255.0 10.101.21.1 1
sysopt connection permit-ipsec
crypto ipsec transform-set dlf-M3UA-set esp-3des esp-md5-hmac
crypto map eplus-map 21 ipsec-isakmp
crypto map eplus-map 21 match address 111
crypto map eplus-map 21 set peer 121.242.37.88
crypto map eplus-map 21 set transform-set dlf-M3UA-set
crypto map eplus-map interface outside
isakmp key ******** address XXX.242.37.88 netmask 255.255.255.255
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
Here for the new TUNNEL i need to NAT the source ip For example source IP 10.150.4.5 to 10.199.222.1 through the tunnel
Pls guide me for this
Vinu
