Managing Cisco Works Logfiles - Problems Running Logrot
Answered Question
I'm trying to run logrot to maintain some large LMS logfiles.
The problem that i'm having is that when I run C:\Program Files\CSCOpx\bin>perl.exe "\Program Files\CSCOpx\bin"\logrot.pl -c
I'm getting the error message
"C:\Program Files\CSCOpx\bin\perl.exe is not a a valid Win32 application."
Any ideas?
Tim
Correct Answer by Joe Clarke about 8 years 6 months ago
Sounds like you're corrupted your Perl executable. You will need to either restore this from a file system backup, or reinstall Common Services.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Wed, 12/24/2008 - 07:49
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
ajawaid002 Wed, 02/23/2011 - 13:37
Hi Tim,
Could you tell me how you replaced perl.exe?
Thank you
Aamir
netzwerk management Thu, 12/03/2015 - 14:40
Hi Aamir,
I have the same problem, could you please tell me how did you fix the problem with perl.exe?
Farzin
