12-24-2008 03:31 AM
Hi Team,
This time no load balancing is required.
Two servers inside (with private IP) need to communicate with clients and servers on the internet. ie, internet client originate inbound traffic to our servers, and also our servers originate connections to some internet servers.
Both of our servers will work indipendently for this purpose.
I have a few ideas to mix and match configs in the ACE. (This was originally working with FWSM setup). I would like to hear some sound ideas to acheive this using ACE only as firewall/router. No plan to load balance at present.
Regards to all
SS
12-24-2008 06:49 AM
ACE will route by default if the traffic is permitted with an access-group.
So, there is nothing much to do if you just need basic routing.
TCP normalization is on by default, so you get the TCP protection.
You can then add per protocol inspection if needed.
G.
12-24-2008 07:56 AM
Thanks G,
The internal servers use private IP address hence need to do NAT on the ACE (previouly it was done by FWSM).
The traffic originates from internal and also from internet.
NAT in both direction is needed.
Static Destination NAT for EACH server can be used if originating in Internet.
What NAT to use for the same serverS if they originate traffic towards internet?
SS
12-29-2008 06:35 AM
The idea is always the same.
Catch your traffic with a class-map, link the class-map to a policy that performs the needed action - ie: nat. Assign the policy to the inbound interface.
Here is an example:
Gilles.
12-31-2008 11:03 AM
Gilles,
Inbound traffic and the related reply traffic can be handled with normal class-map by defining a VIP with public IP.
The above real server with private IP is now going to make a different connection to the internet. ie,
outbound traffic and related reply traffic need handling. (no load balancing planned).
Detination NAT, Static NAT sounds interesting
Source NAT, Static NAT sounds interesting. Mixing these sound very interesting!! I'm looking for sample configs please.
SS
