Change the report type.
Hi Andrea,
Can you be more specific? From what i have perceived, you want to know the bytes transmitted for each application, rite? If that is your requirement, i am afraid MARS will not fulfill the purpose. For such analysis, you need some netflow analyzer (solarwinds, NFC, Manageengine NTA) will give you in depth analysis, or you can use NBAR on IOS if you have your devices on the IOS that support NBAR...MARS simply uses netflow to detect any anomaly in the traffic patterns,it does not correlate the netflow traffic unlike the syslogs. For flows correlation you have to use any of the NTAs that i mentioned before.
regards,
Mohsin
