CISCO sh session vs JUNIPER get session (SESSION ANALYZER)
Dec 24th, 2008
need to verify on a cisco FW (PIX/ASA/FWSM) the sessions.
Is there available a tool for troubleshooting the output like the Juniper Netscreen freeware tool (NSSA) ?
need to know if for cisco exsist a tool like the following for Juniper FW:
1) download the file NSSA : http://performanceclassifieds.net/NSSA.zip
2) download a TFTP server on your pc
3) execute on the FW the following command vs your tftp:
set console page 0
get session > tftp 194.244.1.87 /tftp/session.txt
with NSSA I can get:
Analyzing the Session table via Filters:
There are multiple filters and soon to be cross filters made for NSSA. With these filters you can troubleshoot attacks, analyze routes, vlans, vpn traffic, and types of connections.
- Number of Results displayed
Here you can select how many results from each filter are displayed. Selecting nothing will display all results.
- Source IP
This filter will list the top source IP addresses with the most connections.
- Destination IP
Exactly like the Source IP filter, this will list the top Destination IP addresses.
- Source Port
Lists the top source ports used
- Destination Port
Lists the top destination ports used
- Vlans
The Vlan filter will list the top used Vlans
- Routes
The Route filter will list the top used Routes
- VSD
The VSD filter will list the top used VSDs
- Tunnels
The Tunnel filter will list the top used Tunnels
- Auto Analyze
The Auto Analyze option will do a quick report the Session table. Listing the top 5 of common filters.
