dabels Wed, 12/24/2008 - 07:39
my suggestion would be to show port capabilities and verify they are the same and if so you should be able to do that.
burleyman Wed, 12/24/2008 - 07:55
  • Blue, 1500 points or more
I don't have show port capabilities command on the switch. It is a 4506 running cat4000-i9s-mz.122-25.EWA10.bin
One port is a fiber port (GBIC) on the 4013+ supervisor and the other port is a GB port on a WS-X4548-GB-RJ45V module..
Mike
dabels Wed, 12/24/2008 - 07:57
The reason I said that was that I have seen ports that have different QOS capabilities not be able to sync up on a channel before so I would have to put that in the lab to check it out...maybe there is someone else who has done this on a 4500 We have most of ours on 6500 sorry.
glen.grant Wed, 12/24/2008 - 08:02
  • Purple, 4500 points or more
Usually as long as they are the same speed and duplex you can channel them together. Use show interfaces capabilities to check.
burleyman Wed, 12/24/2008 - 08:27
The only differance, other than fiber and copper, is the Maximum MTU, the firber max is 9198 bytes and the gigabit copper is 1552. So based on that I could do it....correct?
I should have thought show int cap when show port cap did not work...sorry.
Mike
Giuseppe Larosa Wed, 12/24/2008 - 09:00
  • Hall of Fame,
    Founding Member
Hello Mike,
for a working bundle make the mtu the same on both links
Hope to help
Giuseppe
