The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally. New Here? Click here to learn more and get started.
Cisco Community is an active and collaborative place to learn more about our products and ask questions of peers and Cisco experts! Check out some of the most popular conversations happening right now!
Hello, I hope this is in the right board.I have a Cisco Jabber Client on my PC and I have an excel list with contacts and their phone number, I successfully managed to create a xml file to import the names. But i have trouble also importing the phone...
Hi all;After conducting extensive investigations, during which I delved into various topics and related notes, deepening my understanding of the issue, I discovered that I couldn't implement SCEP with an External CA for BYOD scenarios due to a known ...
Just upgraded to 17.9.5 on our 9800 WLC. Seems this statement is missing now... need a bug alert on this? Anyone can chime in. Was there on 17.9.3, unsure on 17.9.4. I do not see any information under the release documentation. We do not have support...
At Cisco Community, we're excited to announce a significant upgrade to our gamification ranking system! We've listened to your feedback and recognized the need for clarity and transparency. That's why we're introducing a numerical ranking system that...
Hi , Good day. I need some help to verify if there is any configuration issue from my end. Basically i have a registered LGW to the webex calling . The incoming call is working fine , but the outgoing call is getting the following error Outgoing ca...
Hello community, what is the best practice to use SMTP authentication ? If we have smtp authentication on mail server is it a good practice to switch it to Cisco ESA ? I can`t find, what is the mail flow when user is using smtp authentication on Cis...
The host for my current server (Windows Hyper-V machine with four or five VMs) that handles my email and web sites is going away. I'm planning on moving that physical server to my house and using DDNS to route that traffic in. Realize this is very lo...
Hello, I am using Cisco Anyconnect to connect to VPN. The system is using Duo Desktop for device health. It is already installed, running and all the checks are ok. However, I am getting this error message and not able to proceed: Install Duo Desktop...
Hello,I have a problem with applying policies from CiscoISE 3.2 on switch C3750. It simply doesn't stop the unauthenticated users from logging in to switch, nor it prevent commands that are forbidden by the created policy. In Live Logs I can see that...
Hey Hi, how are you today?I need to update the telephony-service version from 12.0 to Version 12.5 in order to the expansion key module on cisco phone 8865 works on my router 2951.I read many websites and the most "easy" solution is update the iOS ve...
Hi, can you help me with below. I'm having alerts on my Cisco Wireless Controller : %PLATFORM-1-NOSPACE: bootflash : no space alarm assertdevice#dir bootflash:Directory of bootflash:/381909 -rw- 53477376 Apr 23 2024 09:53:33 +08:00 .USWAP.img273 drwx...
Hello,i have a pc connected to VPC Peer Switch (vPC2) which has the secondary role. vPC2 builts a vPC with vPC1. How can i configure the port to always keep up the connection for this device, even when peer-link goes down (dragging out the cables).In...
