Lan-to-Lan VPN w/ Dynamic IP
Dec 24th, 2008
So I have a Lan-to-Lan vpn set up on my ASA 5505, which was working fine until my client on the other end switched ISP's and ended up with a dynamic ip instead of a static. So now I am wondering if it is possible to configure the 5505 to accept VPN connections from any ip? If not is it possible to accept using a domain name? I can go the DynDNS route, but I did not see any way to use a domain name in the 5505. What is my best option?
Overall Rating: 5 (1 ratings)
