12-24-2008 08:30 AM - edited 03-04-2019 03:13 AM
I have a cisco 2851 and need to know if i can install VWIC2-2MFT-G703 cards to support uo to 16 E1.
Regards.
Mustapha.
12-24-2008 08:48 AM
28XX routers support max of 4 VWIC cards, which means u can have upto 8 E1's and not 16.
Dhana
12-28-2008 08:47 PM
I guess you can have another set of 4 E1's since 2851 has a NM slot.
You can use NM-HDV2-2T1/E1 module along with another VWIC and add 4 more ports (total 12).
There is a nice doc from Cisco to know more on the max number of various interfaces supported on various routers -
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd8057f2e0.pdf
Refer to "Voice Performance" section.
-> Sushil
