nat outside smtp traffic to internal server
Hi all. I have a probmem.
We want to point our external ip address of the PIX that currently accepts smtp traffic and point it to a different internal server.
We currently have the following:
nat (inside) 2 172.17.2.50 255.255.255.255 0 0
static (inside,outside) tcp 55.120.56.34 smtp 172.17.2.50 smtp netmask 255.255.255.255 0 0
aaa-server authinbound (inside) host 172.17.2.50 testkey timeout 10
The above is the current config and works fine. To point the smtp traffic to a new internal server, I did the following:
static (inside,outside) tcp 55.120.56.34 smtp 172.17.5.6 smtp netmask 255.255.255.255 0 0
Once I did that, the public ip of 55.120.56.34 was not pingable and I could not telnet using port 25. I did a clear xlate..and the same thing.
I can telnet to the 172.17.5.6 server using port 25 internall with no issue.
Does anyone know why this would not work?
cisco24x7 Wed, 12/24/2008 - 08:40
  • Silver, 250 points or more
#1: does the pix have a route to get to
host 172.17.5.6?
#2: "clear xlate" will NOT work. This is a
KNOWN issue in some version of 7.x. You should
be using "clear localhost" instead.
