12-24-2008 08:50 AM - edited 03-04-2019 03:13 AM
Alright ... please don't make fun of me. My laptop only has usb, rj45, and rj11 ports on it. Is there any way to console into a switch/router with it? Is there any adapter I can get to make this work?
Solved! Go to Solution.
12-24-2008 08:53 AM
Look for something like this:
http://www.codidirect.com/store/product.html?product_id=217&type=3
You can get something cheaper elsewhere too.
12-24-2008 09:44 AM
u have to select COM port try with all COM port if shown more than one.
12-24-2008 08:53 AM
12-24-2008 09:25 AM
THANKS! With this adapter, using hyperteminal, what do I choose under the drop down menu for "connect using" in the "Connect To" window?
found this for 9.95 and free shipping ... thanks again
12-24-2008 09:44 AM
12-24-2008 10:11 AM
Thanks!
