12-24-2008 09:26 AM - edited 03-13-2019 05:57 PM
Hi: I am trying to find out if the router has a Cisco IOS IP Voice or higher grade feature package. How do I check feature package on a router ?
Ravi
12-24-2008 09:38 AM
Hi Ravi,
I believe "show ver" should give you this info.
Happy Holidays!
Rob
12-24-2008 09:43 AM
Hi, may be you can use the feature navigator tool to check the features that your IOS has
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Hope this help
David
12-24-2008 09:50 AM
Hi Ravi,
This is a very helpful guide:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5460/index.html
Use 'show version' to see which feature set you're running, and see if it includes voice.
hth,
nick
