Unity 5.x.doesn't hangup conversation after press '*'
Dec 24th, 2008
1. Press 'Message' on my phone.
2. TUI working well. I listen my messages.
3. Press '*' in order to leave Unity TUI
4. Instead hangup Unity begin new attempt to sign in to Unity. For add - new attempt begins in English language. Previous session was in Russian.
Overall Rating: 5 (2 ratings)
Rob Huffman Wed, 12/24/2008 - 10:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Pavel,
I'm pretty sure this is the default for the Unity Conversation. Pressing * twice should exit the TUI.
Hope this helps!
Rob
pavelsh_ucs Wed, 12/24/2008 - 10:48
1. Pressing * single - Sign-in conversation in English language
2. Pressing * twice - Sign-in conversation in Russian language
P.S.: Default language - Russian.
lindborg Wed, 12/24/2008 - 10:34
  • Cisco Employee,
You'll want to configure the subscriber exit action (on the SA or via BulkEdit) to be "hangup" then. Pressing * from the top level subscriber menu takes the exit action - by default this is sent to the opening greeting call handler but it can be set to anything, including simply "hangup" if you want.
From the opening greeting call handler if you press * it'll go to sign in which is probably what's happening in your case. Note that if you press * again it'll hang up. From just about anywhere in the Unity or Connection conversation if you hit * multiple times, it'll eventually hang up.
Rob Huffman Wed, 12/24/2008 - 10:37
  • Hall of Fame,
    Founding Member
Hey Jeff,
Thanks for all you do here! Here is my 5 point vote for this answer along with everything else that you do to support us all. These Forums and Cisco in general wouldn't be the same without you!
Happy Holidays!
Rob
pavelsh_ucs Wed, 12/24/2008 - 10:58
I have got hangup if I press * for three times.
Please, How I can setup exit action in administration web-page? I can't find that.
Ginger Dillon Wed, 12/24/2008 - 11:07
  • Blue, 1500 points or more
Hi -
Each subscriber page has a Caller Input section. This is where you'd configure, for a single user, the exit key "*" you want and it's destination - Hang Up. As Jeff mentioned, I recommend using Bulk Edit tool to update more than one subscriber at a time.
Regards, Ginger
pavelsh_ucs Wed, 12/24/2008 - 11:15
Hello
I've configured that. No results. All working same.
After press * I hear sign-in in English.
