Problem moving NAT from Internet router to ASA 5505 for internal mail serve
Hi all,
I am indroducing an ASA 5505 in my network which currently has NAT done on the Internet router conecting to the ISP. They are static NAT entries mapping to a mail server inside the network.
I now want to do NAT and also move the static entries to the mail on the ASA 5505 but I have only one public IP which is set on the outside of the Internet router.
Is there a way to get this work? Thanks for helping
JORGE RODRIGUEZ Wed, 12/24/2008 - 11:56
Yes there is always a way with Cisco..:)
Say you need webserver port 80, RDP, and other mail TCP ports , say local mail server is 10.20.20.100 and only have outside interface as your only public IP address. In this example PLS apply the same principle for Mail ports tcp or upd etc..
static (inside,outside) tcp interface www 10.20.20.100 www netmask 255.255.255.255
static (inside,outside) tcp interface 3389 10.20.20.100 3389 netmask 255.255.255.255
static (inside,outside) tcp interface ftp 10.20.20.100 ftp netmask 255.255.255.255
static (inside,outside) tcp interface 21 10.20.20.100 23 netmask 255.255.255.255
access-list outside_access_in extended permit tcp any interface outside eq www log
access-list outside_access_in extended permit tcp any interface outside eq 3389 log
access-list outside_access_in extended permit tcp any interface outside eq ftplog
access-list outside_access_in extended permit tcp any interface outside eq 23 log
access-group outbound_access_in in interface outside
or create a tcp service object group called mail_server_TCP and only use one inbound acl line using that object group
object-group service mail_server_TCP tcp
group-object eq www
port-object eq 3389
port-object eq ftp
port-object eq 23
access-list outside_access_in extended permit tcp any interface outside object-group mail_server_TCP
Use these examples bellow as ferences but keep in mind to use the keyword (interface) in your static NATs
and use the keyword ( interface outside ) in your inbound acls for using your outside interface public IP address.
Port Redirection(Forwarding) with nat, global, static
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00804708b4.shtml
Mail related links
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080683db5.shtml
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008067cf3b.shtml
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806745b8.shtml
PLS rate post if it helped
